Ivy Bridge Engineering Samples / Core Specs Released
FTLN
Active member
Intel today released the core specs for the upcoming Ivy Bridge Processors.
Taking advantage of the ISSCC (International Solid-State Circuits Conference) 2012 Conference to show off some engineering samples.
Specs are as follows –
160mm x 160mm core area (25 percent reduction on previous Sandy Bridge Cpu’s)
1.48 Billion Transistors (22nm Process) 28 percent increase over Sandy Bridge
Configurations - 4Core+GT2Gpu, 2Core+GT2Gpu, 4Core+GT1Gpu, 2Core+GT1Gpu with the foremost being the flagship i7
Dual Channel DDR3 / DDR3L Memory controller with support of speeds up to 1600mhz
Full DirectX 11 Compatibility with support for up to three display’s via Display Port
What makes you say that ?
I got the info mooling around some chinese site where they attended ISSCC... Could be wrong but sounded pretty legit.. Maybe just a typo on the image
as sieb said.... those slides are ancient
they are the references for the ****bridge series of chips
IB will not go backwards - IB may be based on the same architecture, but it will not be the same.
there is a while to go before IB's release and alot of speculation as normal.
i am not sherlock, but i doubt the 'official release' ivy specs will be anywhere close to sandy's.
So can anyone translate this? Meaning am o better of getting a 3930k for My new rig or shall o hold back a little while longer and get a ivy? Thanks in advance!
Deffo wait a bit since its huge prize difference for SB-E 3930k vs IB 3770k. Well anyways, thats what i am doing
IB-E is launched in Q4 also, so its a dilemma with all this new stuff soon to be released.
