Well.... Its happened! I`m now running (of sorts) under a Mach2GT!
http://img269.imageshack.us/my.php?image=imag00014fc.jpg
http://img269.imageshack.us/my.php?image=35be.jpg
http://img57.imageshack.us/my.php?image=sideforep9hj.jpg
http://img57.imageshack.us/my.php?image=frontpanel7nl.jpg
That clock speed, from what I`ve seen hasnt changed, despite the OC i`ve tried so far.
No real benchmarks yet... My VDIMM limitations knee-cap my SuperPi runs- my old bench rig using HynixD and my Winnie at 2880 still have the edge overwhere I am now..Might try the TCCD coz that can handle slightly higher speeds. CustomPC wont run at all. That needs a think. Not got 3DMark installed yet.
2710MHz at 1.52VCore (lowest my Mobo will supply) is the only noteworthy thing i`ve seen so far. (hit higher, but nothing special)
Need to see if I can align the mach box and Case better...worried about hurting the hose. Cabling needs a bit of work too. The cable ties are a bit ghetto but the screws wont make contact with the CPU plate guides. Maybe I should just buy the right CPU kit....
K
K
