SieB New member Aug 15, 2012 #2 Is it a reference card? If yes, then yes there is http://www.specialtech.co.uk/spshop/customer/search.php?substring=7870
J jamesriley94 New member Aug 15, 2012 #3 If you're on about the dual fan version - yeh, it is reference
G garih New member Aug 15, 2012 #4 That backplate is for water cooling tho. Can u still use it with the standard sapphire cooler
J jamesriley94 New member Aug 15, 2012 #5 Yeh, it's fine. It isnt for watercooling really - it does the same job - covers the PCB so it looks nicer
G garih New member Aug 15, 2012 #6 having looked into this i dont think it will be possible to fit http://www.ekwb.com/shop/EK-IM/EK-IM-3831109856802.pdf the mounting screws at the end of the card need to be screwed in from the cooler side. and with the air cooler in place ther is no access to these holes... oh well, it was a nice idea in theory
