mehere
hi all
after a furniture move in the room my case is now on the left-hand side of me against a wall so all the lighting/window and kit is hidden
Thinking off stripping the case and swapping it round so window face's the right/me
having a good look round it before I start it looks as if it is fairly easy, drill loads of rivets take MB tray and rear panel out together turn over and refit it, it even looks as if all the holes are predrilled on both sides of the case as standard
my question is, has anyone done this before? is there anything I need to know, is it as I think it looks?
my other thoughts are, at the moment its water cooled running from bottom to top
is inverting the board going to make any difference to any of the cards/block being upside down
