Interferon "SHINOBI XL WINDOW"
randell1993
Hey Guys! I posted here sometime ago asking a comment about a liquid cooled system and was planning to build on a NZXT Switch 810 but sadly its already a month talking to different distributors here they arent able to get one so i get my second choice which is this.
This is my second build but my first time doing a Liquid Cooling setup i know the parts are quite a bit outdated and slow.
This also quite an experience with multiple leaks yah! LEAKAGES everywhere and redoing most of the connections. Also encountering some incompatibilities with my full thickness radiator but managed to do some minor moddings.
My Rig Specs
Motherboard: EVGA P55 SLI,
Processor: Intel Core i3 530 @ 4.0GHz,
RAM: Corsair XMS 8 GB DDR3 @ 1458MHz,
GPU: ATI Radeon 7870 GHZ OC ED @ 1250MHz GPUClock 1350MHz GPUMem,
PSU: Cougar ST 600watts,
HDD: 1TB SEAGATE BARRACUDA 7200rpm + 500GB SEAGATE BARRACUDA 7200rpm,
Chassis: Bitfenix Shinobi XL Window
CPU COOLING: Custom Liquid Cooling system ( Thermochill 360mm Radiator (3 SP120 Push Fans)), D-Tek CPU block, Swiftech MCP655 Pump, 100ml Acrylic Cylindrical Reservoir, EK Compression fittings and rotary devices and Tubing, Mayhem Pastel White(BLUE DYE) Coolant. 1 120mm Stock Bitfenix Back Exhaust, 1 230mm Stock Bitfenix Front In, 1 92mm HDD Cage Deep Cool UF
Accessory Devices
Monitor: Acer x193w 1440x900
DVD: External Samsung Slim DVD RW
Mouse: A4TECH X7 Optical
Keyboard: ACER Standard Keyboard
Audio: Headset ( Corsair Vengeance 2000 Wireless Dolby Digital 7.1 Virtual Surround) Speaker (Edifier X100 2.1)
Game Controller: XBOX 360 Wired Controller
Future Upgrade Plans
Next Year:
Motherboard: Undecided LGA 1150
Processor: Intel 4770k i7 (HASWELL)
When Available:
VGA: AMD Radeon 8970+GPU BLOCK
Don't know when:
Keyboard: Logitech G15
Soon Enough: 2 SP120 Fans + NZXT LXE Fan controller
Images:
Added Bitfenix Recon Fan controller and NZXT Hue
Im open for your critism and suggestions!
looks great, but thats a lot of tubing for such a small loop... maybe mount the pump higher up? just below the res ideally, then you could do away with the third piece of tubing all together
was thinking of the same but for some resources issue was only able to produce this and it was my first time doing LCS. my future plan would be much similar ill upgrade the reservoir to 250ml one and have a GPU block and another 120mm Rad to have this flow
res/p>gpu>120rad>cpu>360rad
