Intel PC, Budget £1000
MadShadow
Active member
Okay, so I have been trying to choose parts for a £1000 PC, but I keep going over budget, so I need help. The CPU must be from Intel, preferably overclockable (depending on what is possible in my budget). The GPU can be Nvidia or Amd, depending on what has the best price to performance. I will mainly use this for gaming, so no need for extremely high end CPUs. If you could help me choose my hardware, that would be great. Thanks in advance :D
Came up with this on Scan. Hope you like red :)
Or otherwise I could have a look at another colour scheme for ya.
I'll give it a go but seeing as you're in Russia that might be an issue.
PCPartPicker part list: http://uk.pcpartpicker.com/p/3RMTH
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (£163.94 @ Amazon UK)
CPU Cooler: Corsair H75 54.0 CFM Liquid CPU Cooler (£58.49 @ Ebuyer)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard (£89.99 @ Ebuyer)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory (£71.05 @ Amazon UK)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk (£55.89 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£52.79 @ Aria PC)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card (£295.19 @ Aria PC)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case (£79.99 @ Amazon UK)
Power Supply: Enermax NAXN ADV. 650W 80+ Bronze Certified Semi-Modular ATX Power Supply (£61.74 @ Amazon UK or you could get an RM550 for slightly less)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) (£69.65 @ CCL Computers)
Total: £998.72
There's nothing I would change about that build at all, but if you don't need to pay for an operating system you will free up a bit of cash to go for the 290X GPU for a few more fps.
