Korreborg
Member
But that's under the assumption that the 4 cpu's in one will just work.it's pretty easy to assume the performance using some simple maths.
Did you watch the Le Mans this weekend, not everything always works as intended
Did you watch the Le Mans this weekend, not everything always works as intended![]()
It already works. Ryzen is made in quad core clusters.
I see a difference, and the possibility for problems.
i am only interested how threadripper works for 3d max, maya, after effects and premiere pro.
could not care less about playing games on TR....
How does Ryzen work with them? = answer.
compared to the latest intel x299 offerings....
yeah thats all fine speculating. i can do that too.
but the real world tests will show how much this is worth.
i never expected the skylake-x 10 core to have such bad thermal behavior.
i thought it would be on par with the broadwell-e.
everything else is basically close to what i thought.
maybe TR has some good/bad surprises too.
A little bird in Taiwan says that Intel are working on soldering later CPUs..
If you're referring to that obscure bitsnchips website, please don'tThey may be soldering 12-18C parts, that I'd believe, but not the current offerings.
Nope apparently they are working on soldering all of them.
Please don't believe what they have told you. They don't give a f**k about you or your overclocking ambitions. They are spitting in your face. In the same way they spat in every enthusiast's face when overclocking started. They immediately did everything they could to stop it, and any "accident" they have left in place has been shut down pretty quickly.
The only reason they are finally figuring out what to do about it is AMD. Before that they couldn't have given a rat's arse.
It's kinda like having a friend that does nothing but dump on you and take your money, then some one comes along to compete for your friendship and your crap mate finally starts treating you better. Not because he wanted to, because he has no choice.
If you don't think a billion dollar corporation like Intel can work out a way to solder CPUs? your lookout dude. AMD have it down pat.
THIS. Barnes Wallis would expect no less.
Chill a bit for your own sake?You've conveyed your dislike for Intel and enthusiasm for AMD well over and over again regarding these matters, it's all good
Id hold fire on that for a bit.... Im debating weather or not I drop a bomb about CL
If you bought a Ryzen rig in the past 2 months, you unwittingly signed up to be a beta BIOS tester, and you aren't getting paid for it either.![]()
This I agree with 100% but not just bios - youre an active hardware tester.
Agreed! Ryzen was a SUPER rushed release, and the kinks are still there months later. I wonder how many more months it will take for these AGESA updates to improve, and if that will even solve most peoples issues.
I've flashed my C6H BIOS about 15 times with multiple RC BIOSes, and even the mighty Asus isn't close to getting the kinks worked out yet. It seems with every BIOS, some things get better, others worse. This latest RC BIOS (1401) seemed to improve memory compatibility, but broke my RGB LEDs (they work, but they don't shut off on power down, even though the BIOS says to). That *used* to work fine, but broke in the latest BIOS. But not for everyone, just me, go figure. Asus is scrambling in the wake of all the Intel stuff, and it seems like things are slipping through the cracks.
There's a thread on OCN that is WELL over 2000 pages, and it's FILLED with stuff like this.
