Avet
Active member
i feel like everyone is slowly converging on the same argument which essentially boils down to... 'horses for courses'
It is not. The point is, as Intel CEO is trying to allude, and as I have stated above, that many benchmarks are pointless and don't give you the correct answer. And they couldn't be further away from the real-world performance. In all "productivity" benchmarks (Cinebench, V-Ray, Corona, Blender, etc.) 3950X beats 9900K by a hefty margin. And all reviewers are singing like a choir "3950X is much better for productivity because it beats 9900K in all benchmarks". But 3950X is NOT a better CPU than 9900K for any application that uses those renders. Because you don't render with CPU. Don't get me wrong they can both do a very good job but the performance (mainly viewport in all those apps) is on the side of Intel and it is noticeable and measurable.
The "reviewer consensus" is: "Don't bother with Intel if you want productivity you must go with AMD." That is so completely wrong.
PugetSystems is recommending 9900K as the best CPU for Editing Rigs!!! Why is that? And they are a very smart bunch of people.
The only workload I would explicitly recommend AMD over Intel is 4K and above video rendering.
For everything else like 3D modeling (3ds Max, Maya, Blender, SolidWorks, Sketchup), design (AutoCAD all variants), Photoshop, Music Production, ... Intel is the better CPU.
Why? You might ask. Because of this:
- All those tasks cannot be properly parallelized as Tiled rendering can. It means that the tasks are executed in sequence and that is where Intel's superior latency and single-thread performance comes to light. It doesn't matter that you have 32 cores because 28 of them can't do a thing until 2 cores finish their task. That is why Intel CPUs are superior in gaming.
- All applications in the past 10 or more years are specifically designed and optimized for Intel. Sad but true, and you can't go past it. It will take a long time for developers to redesign everything for AMD.
The actual real-world performance king, despite all benchmark results, for production and gaming (except 4Kvideo editing) was 9900K and now 10900K and not 3950X.
I must emphasize again the performance gap isn't gargantuan. They are both good CPUs. Expect it to be like in games. And there Intel is undisputedly better.
And again I am not Intel fanboy and everything I have said in this post is provable. So please restrain your self from hateful comments.
Edit 1: AMD hype is mostly propagated because all reviewers are mainly doing Video editing and that makes them a bit biased towards AMD. Because Ryzen is a really good CPU for that.
Edit 2: Also if you are a Linux GURU and you do 7 compiles at the same time while having 6 VMS running Threadripper is Godsent.
