WebMaximus
Anyone in here having an MSI Z390 ACE and successfully installed a 2280 sized M.2 SSD in the M2_3 slot?
I'm trying to figure out how to install my Samsung 950 PRO in M.2 slot 3 to take advantage of the M.2 SHIELD FROZR.
Where I'm stuck is how to remove the mounting screw from the 2260 mounting hole. Removing the screw is easy enough but for the mounting screw I have no clue what tool I'm supposed to use to remove it.
The manual simply says on page 33 I should remove both the screw and mounting screw from the 2260 mounting hole and even comes with a graphical illustration but again...no clue how to accomplish this without risking to damage anything.
