I'm confused 560ti of 6950
01kensha01
I don't know what to get 560ti for £200 or the 6950 for the same at overclockers. on the graph the 560 dose slightly better in the games but the 6950 does a lot better in bench marks. I am looking to buy a card that will do me for the next 2-3 years, so is the reason the 6950 does better in benchmarks because of dx11 which isn't fully utilized in today's game. so what would be better considering I want this card for a few years and dx11 will probably be used more and maybe the 2gb of ram in the 6950 will be better in the future.
thanks.
Benchmarks do not reflect real performance if you want to compare cards look at performance they get in games. The 560 uses less power, is quieter and cooler than the 6950 and it's also better at DX11 personally I would go for the 560 the only reason I would get a 6950 is for Eyefinity other than that go Nvidia.
+1
Everything has been said
well considering a msi 6950 rev 1 is available for £195 personally i'd take that, why? well one reason is that you can flash it two a 6970, so it will be faster than a 560, plus the fact that it has 2GB memory. Both are great cards so its upto you.
Yer well heard of that breaking loads cards plus this current 6900 series seems to have loads tech issues anyway.
For me the only reason to buy an AMD graphics card at the moment, would be Eyefinity. Hands down every NVidia equivalent will beat the AMD versions.
