i7 build
JordanDoyle
Hey guys, is this a good gaming/recording/editing build? And is it compatible?
Seagate ST2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM)
Komputerbay 32GB (4x 8GB) DDR3 PC3-12800 1600MHz DIMM with Heatspreaders 240-Pin RAM Desktop Memory 9-9-9-24 XMP ready
Asus 1GB Radeon HD 6850 DirectCU PCI-E2 (two of these)
Sony AD-7261S-0B 24x Internal DVDRWRAM SATA Black Lightscribe
Club 3D ATI CrossfireX Internconnect Cable (CAC-CB)
Asus P8Z68-V PRO/GEN3 Motherboard (Socket 1155, ATX, DDR3, USB 3.0, HDMI, Bluetooth Module)
Intel Sandybridge i7-2600K Unlocked Core i7 Quad-Core Processor (3.40GHz, 8MB Cache, Socket 1155)
CIT 750w Gold 12CM Silent Atx Power Supply
CiT Mars Midi Tower Gaming Case with 2 x Blue LED Fans & LED Display - No PSU
by CiT
Thanks guys!
What FPS do you think I'll get?
Please tell me you havnt already bought that ram, you most likely will only realyl need max 16gb of ram, get either Corsair, G.skill, Mushkin or Crucial
hi jordan what have you got already and what can you send back?
take a look at this for a mobo http://www.dabs.com/basket
plus use code april10 to get £10 off when you spend £150 or more must be used to day (use some creative thinking with this code i.e family)
Given the budget I think this build needs to be streamlined a little bit.
Is it going to be mostly for gaming or for you recording/editing (and what are you recording and editing?)
This will decide where you need to spend the money.
Also, yea, what have you bought and how much of your budget is left?
lol no money management :/ is that what you're doing with your life.. all bad should've bought the cooler/psu/case first then bought the last 4 togeather
