i7 950 vs i7 970
Which is better,relative to price
  • i7 950
    Votes: 0 0.0%
  • i7 970
    Votes: 0 0.0%
  • Both are shit
    Votes: 0 0.0%
  • other (please comment)
    Votes: 0 0.0%
  • Total voters
    0
Superman23
hey guys,
I currently have a i7 950. I have been offered a new i7 970 for a reasonable price (trade-in)
Is it worth the upgrade?
How the temps on the i7 970 (approx)(stock)
Big speed difference?
Overclockability?
Any other nice facts,advise you got for me will be appreciated.
Thanks guys!
i7 970 is a great CPU. It is worth the upgrade. 6 cores with 12 threads is an absolute performer. From my experience the temps are lower because the 970 does not require as much voltage as the 950. This is just from my experience though.
The 970, especially with the new price cut. The 970 is a 980x at half the price. And overclocks just as well with a little knowhow.
I'd go for the 970 if the price is right mate
Im going for a 970 as well cant wait. Ya can only overclock a 920 for so long before you start to get bored. lol
hey guys,
Overclockability?
Thanks guys!
970 ftw.
and
sell me ur 950 cheap
If the price is right I'd go for it. I fold though. If you don't fold or encode or do some other CPU intensive task you will probably see/feel zero difference. What do you primarily use your PC for? If all you do is game I'd say save your money.
Rep + a lot but can just give 1
The 970 is 32nm fabrication process, the 950 is 45nm. That adds another + for the 970 IMnsHO. From a power consumption/heat dissipation perspective you're kind of getting those two extra cores for free. Both CPUs are rated at 130W TDP.
There are also frequency scaling benefits within the individual cores. Signals have less distance to travel from one element in the core to another.
Also, the 970's multiplier is one bin higher.
All of those factors should theoretically enable higher overclocked speeds.
Just thought I'd try to contribute some things that no-one else had mentioned yet.
In theory, theory and practice are the same. In practice they can be quite different.
