Hi im new here, but im a bit lost and need sum1 to confirm if im doing good or bad so far.
So brand new System is :
i7 4770k
GA-z87x-ud3h
2x 4Gbs HyperX red
Silent Pro M2 850W
Seidon 120 WC (Its what i could afford after buying everything else, and for the mild oc i need i thought it should be enough)
So, I run stability tests at stock speeds over night and went with no problems.
So first thing in the morning went to the BIOS and set the multiplier to 44, ram mult to 1600, and Vcore to 1.175v. Thats all I did and booted normally.
My first question would be: Am I ok just changing those 3 things? Or can something go wrong just cuz I needed to change something else in the BIOS? the system is working fine at this point. Tested for 1h40mins with AIDA64 test and the standard IntelBurnTest.
Also, if everything is fine, should i keep going down in volts ? I mean Im really satisfied with 4.4 Ghz considering the cooling i have is not strong enough for more.
I know I should test for much longer times, but i wanna know if im on the right path before i keep going on with long stress test. Thanks for your time
i7 4770k
GA-z87x-ud3h
2x 4Gbs HyperX red
Silent Pro M2 850W
