P prole33 New member Jun 6, 2013 #1 here's the reading from prime95 after a 30min burn, tell me what you think etc etc i know the vcore is pretty low but runs stable so far.
BradleyW-H New member Jun 6, 2013 #2 Temps seem fine. If you have managed to get to 4.2 under that Voltage I'm gonna cry. :'( I would try running cinebench as well see what that does.
C Carbon20 New member Jun 13, 2013 #3 Im running mine at the same clock, same volts and getting the same temps to. I say you're probably good to go! Might want to try the Intel burn test just incase.
J jamesriley94 New member Jun 13, 2013 #4 You need to run it for a lot longer than 30 minutes to ensure stability. Go for 12 hours and see what happens.
AverageNinja Average Penis Too Jun 13, 2013 #5 jamesriley94 said: You need to run it for a lot longer than 30 minutes to ensure stability. Go for 12 hours and see what happens. Click to expand... This. It's amazing how many people think their OC is stable after 15~30 mins of prime95 I would also like to suggest OCCT instead of prime
tinytomlogan The Guvnor Staff member Jun 13, 2013 #6 OCCT - Linpack - 90 Free memory - use all cores - AVX compatible NOW your PC will get hot and cry in pain.
