Makis
This error means to low voltage?
Hi there now im running my i7-2600k with same bios settings like TTL without any power saveing Features!
1,3v @4,2 Ghz is this ok voltage whise for 24/7 usage and will it degrading my PC or not? ?It seems finally to be stable
I tested before 1,245,1265 1,275,1,285,1290 stopped because of error you can see above..what that means ^^)
i tweaked voltages since wednesday starting at stock voltage occt stable 12hrs 1,100v and going up to 1,3vwhat are your thoughts please let me know.
Do you suggest let settings or enable power saveing features?
My system:
I7-2600K @ 4.2 Ghz 1.3 Volt
G1 Killer Sniper 3 Z77 Bios F8
8 GB Corsair Dominator Platinum 1600 MHZ CL9 no XMP
Gigabyte Gtx 670 OC
Samsung Pro 128 GB
