Managed to muster the courage to do my first bit of voltage increasing and intermediate over clocking.
I've achieved stable and good temps for a 3.8Ghz @ 1.25v.
Right now I'm testing a 4Ghz OC @ 1.3v, seems to be alright however the 100% load temps are sitting at 65,69,69,78. Is this an alright temp? I tried searching but could only find newer gen i5 temps.
w
Edit: 45 minutes into 100% load test and both CPU fans stopped causing a force shutdown. The fans work if I plug them into a miles, but not the CPU header anymore, perhaps a bad cable? (Fans>splitter>3pin to 4pin CPU header). I'm thinking items the 3pin to4. Using a ph-tc14pe
w
