Ya93sin
Doing this on my new build,
Mobo-ASUS P8Z687V-PRO
CPU-Intel i5-2500K
RAM-Mushkin Blackline 8GB
This is going from stock, 1.224V for the CPU @ 3.3GHz stock, 3.7GHz turbo, 100.3 base clock, Ratio 16-37 (underclocked-turbo).
So for the overclock, I used the ASUS in-BIOS tuner, and got:
(at 1.248V CPU voltage)
Is this what I should be expecting? I was wondering whether I should just disable the iGPU so that the CPU can overclock better.
This is a 24/7 OC, also I'm wanting to keep the underclocking-turbo modes instead of one constant frequency, at least until uni.
Also should the voltages be lower?
Of course I'm going to do some of my own research, test it properly now, but I would very much welcome your thoughts and feedbacks.
Thanks
CPU-Intel i5-2500K
- 3.43GHz 'normal' clock (at 33x multiplier)
- 4.32GHz 'Turbo' clock (at 42x multiplier)
- 103.0MHz BCLK
- Ratio 16-42 (underclocked-turbo)
- iGPU is 1450MHz instead of 1100MHz, it just did this automatically, I care only if its inhibiting the CPU OC potential)
- RAM is now 9-9-9-24 @ 1648MHz, 1.35V as before, so effectively a 48Mhz increase, but I think that's due to the BCLK increase by 3MHz)
Thanks
