i5 2500 or i5 2500k
michaela
Hi All,
I am not a gamer so am not really looking to buy a graphics card so i was wanting to know is it worth getting the k version to get the better graphics.
K version will only have better graphics if you plan to overclock it, if you aren't going to overclock it the K version is no better than the normal 2500 for you.
In the current collection of Motherboards/chipsets there isn't a set which lets you overclock and use the IGP (integrated graphics processor) at the same time. As far as I can see on the Intel site, there is no difference in the IGP of the 2500 and the 2500K. There is a difference between the i5 2500 series and the i7 2600 series, in terms of the IGP.
So it's either overclocking or using the IGP.
The P67 boards support overclocking, the H67 boards support the IGP. IIRC the Z68 chipset (which is not yet released) will support both, but don't pin me down on this.
So the 2500K is in fact useless compared to the 2500 in this case. My bad
Unless the chipset you mentioned is coming very soon?
Last thing I heard, was Q2 2011. It might be pushed back due to the Sata problems Intel had with the B2 chipsets. However I've not yet read any confirmation on this nor on the Q2 release.
the i5 2500k has Integrated HD 3000 and the i5 2500 has Integrated HD 2000 so would ther be much difference in the performance.
I can't believe I didn't find that.. sorry for causing confusion here.
yes the 3000 series will beat the 2000 series IGP, the 2000 only has 6 Executive Units, where the 3000 series has 12. This will mean a performance increase.
if it's worth it, that will be up to you, where will you be using the PC for?
I read somewhere that you will be able to overclock and use the IGP on the Z68 chipset. I don't now how true it is though but I don't see why they would make a different chipset for features already supported unless they were going to combine them, but only time will tell and we will have to wait and see.
With £8 difference between the 2500 and the K version, you mayswell get the 2500K version seeing as it has roughly twice the gfx performance with the integrated HD 3000. It will be worth it in the long run, even though if you do decide to game in the future you will want a dedicated gpu.
And if you ever sold it on, overclocking capability has a big effect.
For the minor price difference its a no-brainer. Get the i5-2500K.
