Time to unlurk now and see if anyone knows what went wrong I guess. So I built a new system after my laptop died, and amongst the various bits and pieces I've ended up with:
MSI Z77 MPower (I just now realized the pun in mpower...)
Intel i7 3770K
Corsair... *ahem*... 'CMX8GX3M2A2000C9' 2x4GB DDR3 RAM
The CPU is incidental in this AFAIK but it seemed potentially relevant.
I read when installing it that the RAM would generally like to start out furthest from the CPU and skip rows. The MSI instruction book shows what appear to be DIMM 4 and 2 populated in the case that there's only two sticks of RAM. I say 'appear' because it's listed 1-2-3-4 on the MB itself and in the book, with 1 being nearer the CPU, but that may not be true (I'll get to this).
When I started everything up, the BIOS showed the RAM at being only slightly above 1k MHz (I forget the exact number now but less than the 1.333 MHz 'SPD' thing on Corsair's page). I naturally wanted to get it to 2k MHz but I figured I could leave it alone for the time being and get things stable first, which actually took about 2 days simply to dig up drivers for every conceivable part and the smaller pieces thereof.
Last night I figured I'd finally got the last driver, windows seemed to have quit annoying me with BSODs for a bit, and I left the PC on copying some backed up files from the network. A few hours later, it was still running, but the screen was black (still on) and though I suspected it happened because I forgot to kill that 'put hard drives to sleep' option, it would not wake up or otherwise respond so I turned it off and went to bed.
When I got up today and tried to start it up, windows had a new BSOD (3B, 7E, 7F, something about CI.dll) every time I attempted to start it, or repair it, even from the CD. Even my random ubuntu live-usb faceplanted and complained about corrupted LZMA data. Looking at google results suggested memory issues were the common factor. Some people had said they ran memtest86 for hours and come up with nothing, but removing some/most of their RAM still fixed it.
As memory had also been a common theme in previous BSODs (albeit broken up more and with driver issues also being possible factors some of the time) I finally just took out the RAM in DIMM 2.
I think.
Windows managed to boot from the CD and run an uneventful check for errors, so I rebooted (and had to select the HDD manually to stop from going to the BIOS over and over and over... not sure what's up with that, but okay) and windows managed to start up. Things seem to be working fine, except for bewing down to 4GB of RAM - what MSI ControlCenter calls 'DDR3-1066 (533MHz)' - but I figured the other stick was just demented.
However, MSI CC also says that slot is 'Dimm 2'. According to the little printed text on the MB, that slot is 4, not 2. And in either case I'm not sure how the slot at the end of the row could possibly be 2, but it's their own control centre. Is it just wrong? Could the slots actually be really weirdly ordered, and that other stick of RAM was just screwing things up because it was out of place?
I'm sort of hesitant to just start moving things around to see what happens, in case I actually cause damage to something instead of finding out what the problem is. If I started it up with both sticks of RAM in the places they've always been, but swapped around, would anything happen to the (currently) decent one if the slots are really weirdly arranged?
Intel i7 3770K
I think.
