Jubilant Lancer
Greetings
c3d:!
As some of you may know I have begun my first PC build experience (you can follow my progress in my thread under Project Logs) and I would like some advice on the CPU cooler I decided to pick up.
First off what I purchased is a Zalman CNPS9500A-LED 92mm
( http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223 )
My reason for getting this was first off it is a pretty cost effective option (Amazon had it for only $40) but it had pretty good RPM's, a low decibel level, and it comes with a fan controller for switching between silent and low noise speeds. Another awesome thing was it has a blue LED which matches perfectly with my build. So my first question is; How do you guys/gals here feel about this particular cooler, what are things you like/don't like about it and why? Second question is how effective do you think this cooler will be for overclocking my system?(Obviously overclocking just take monitoring to see your limitations, but I am asking how high do you think how high the limitations this cooler may set for me?)
I would really appreciate any input on the matter and I appreciate your time.
Cheers!
Cheers!
