name='ajbrun' said:http://www.tosk.co.uk/8800/
"It will fit but the card kiss's the HD cage, Also depends
on mobo and how many hds used"
Also, the GTX (which is what I'm getting) is in blue, so maybe that means that it won't fit, but the GTS will?
Either way, I'd rather not risk it.
Get a bigger Lian-Li, dude.
Lol ok enough with that. If you can't go Lian-Li, then I'd give Cooler Master a look, even though they are jerks
