I`m actually making some progress!
K404
I have plenty of ideas, but I`ve shown very little of what i`m actualy DOING so... Heres a couple of the latest.
Err.....the PSU is held onto the backplate by being forced between the 2 lips that sit proud of the back of the plate. Will post a pic of that in a bit. I`ll be working on that. I cut out the 92mm fan grille in the back to route all the cables. You can also see the plate Mr Stocky made for me...curently sadly devoid of a compressor
Nothing special, but reasonably neat
This needs a quick rethink... the side panel wont go on due to the thick sleeved cable!
Thanks Mav! Nothing really special going on, but better than posting 4million if/when I ever finish this :)
Its a Chieftec Dragon Full-tower I think.
Kenny
Yup, those ARE burn marks at the edges...these were ever so gracefully cut with....an angle grinder. Easy access to the back of the CPU for cooling changes and insulation checks :) The chipset access hole is maybe a bit more pointless- now that I have the option, I`m sure I`ll change my Chipset cooling several times a week. Or not.
I hate IDE
Finally some pics of the case mods, i swear Kenny with the amount if ideas you have you will end up with your case just being a pile of cut up metal shards on the floor :D
Looking good, loving the angle grinder.
G
Give it time, G....give it time!
Thanks for the compliments, Apart from maybe a mobo change (and the necessary GPU change for PCI-E), and maybe a CPU change if I see a good price, I think I`m set for this project :) It only took....4 months?
looking forward to getting it up and running :)
Kenny
