I don't know where to ask modding help
Innocent159
I want to mod my Gigabyte Luxo M10. I want to make my hdd cage removable, Is it possible or is the only way to improve air flow by removing it completely?
I want to remove it but than again what if i buy another hdd?
Come on dude some things you have to work out for yourself.... Im struggling to understand why this needed a post at all tbh.
"what if you buy another HDD"
Why not just buy one big enough for it all if you replace anything...
Those life choices. Man, they mess you up.
Sorry Guv, I just wanted to know is there a way of removing the whole case and modding it to make it removable but I want to be able to use it again.
Edit: The cage will be removed but Is there no way i can make it like some of the corsair cases where you can take it out when you want to
#I hate this case
Plenty of potential for modding in that case dude. You could always mount drives on the floor or make a small dual drive mount.
I was thinking of cutting the whole hdd stand and switching it 90 degrees.
allowing air flow through the opening. I would than put the HDD in the lowest bay.
But how do I fasten it again (rivets)?
Rivets or small nuts and bolts like Davva2004 said earlier. Rivets would mean that if you wanted to move it later you'd have to drill them out again.
