hyperX vs corsair
If you are just gaming or really doing anything else, you wont notice a difference. I would go for the Corsair ram, but that's just because of the looks.
Performance will be the same, same speed, same voltage, Corsair has a bit tighter timings but you won't notice the difference between them. So go for whichever you like better.
Personally I like the Fury a little more however I can vouch that aesthetics wise the Vengeance pro looks the mutt's nutts.
will the better timings help with 3d rendering? if i overclock the corsair ram will it do any better? and which will look better in red with the maximus VII hero mosfat sinks?
