HWMonitor
icetronix
Firstly sorry if this is the wrong section.
Is it normal for HWmonitor to have buggy CPUTIN and AUXTIN temp listings?
My CPUTIN doesn't show AT ALL and the AUXTIN wont give me a reading unless i start up COD and then as soon as i alt tab or exit the game the only temp it shows is "max"
I know i just need to watch the core temps but if its a bug with this mobo i would rather RMA now as my new case will be arriving in 2 1/2 weeks.
Thanks for the reply.
Ya im using 1.17, i guess im just paranoid about it as i am with all new hardware.
Its just stuck me as odd that its shows when CoD has been running but wont with anything else.
The system is stable and i have had no other issues, perhaps its just faulty sensors or the board is just to new? {P6Z68-v EVO}
EDIT
Just installed PC Wizard and it lists the temps so it seems to just be a HW Monitor issue.
Ahh, that could be it, I know when I first got my P8P67 that the latest version (1.6) of HWM wouldn't read temps from it for my CPU or GPU but they fixed it with 1.7. I use RealTemp now i find it easier to use.
