HWMonitor temps & core0 temps
happyshoppa2
On my 2600k/UD4, it seems HWMonitor is all over the place, latest version 1.17. RealTemp and CoreTemp both agree with each other [edit: scratch that, they no longer agree with each other at all
]. I noticed Tom switched to using CoreTemp in the recent videos, is that because of issues with HWMonitor + Sandybridge?
Also my core #0 is much cooler than the others, I know this is common but the difference is a crazy 10 degrees under full load (noctua nh-d14 cooler). Should I take it apart and redo the cooler/thermalpaste etc?
I have the same issue with my 2500K except my core #3 is hotter than the other cores. I have tried Cupid HWM, Real Temp and Core Temp and they all give different readings as well as the temps going up and down all over the place. Although, when on load the temps seem to even out across all cores and they are with in 1-2c of each other. It's not causing any problems and everything is running stable so i'm not to worried about it ATM.
