J JN New member Apr 2, 2009 #2 name='nunzio' said: Anyone got any advice on a good one with vdf/lcd? Click to expand... How much you looking to spend dude?
N nunzio New member Apr 2, 2009 #4 Dunno, Max £150, I have looked at some like the zalman ones, but I dont need the LCD screen. I like the Antec ones, so might go that route, as it comes with a remote.
K Kojak71 New member Apr 6, 2009 #5 Given your budget, Antec is going to be your best bet. The Remote Max case will fit full sized components and has good airflow and cooling properties.
