Hi guys
Trying to install the above printer it keeps throwing a windows error of "Cannot install hardware" "The specified environment is invalid".
Does this even after wiping all traces of HP off the computer. The cable works fine with a different printer also.
Basically you run the HP installer (both off the disk or latest driver off the net) and it gets to the part where it detects the printer/tells you to turn it on and windows detects it - then throws that error!
argh
does the same when you manually search for the driver file too - this is on xp x32.
i'm at a loss and probably gonna try a format/reinstall
argh
