Guys i don't post here too much so forgive me if this has been answered in the past. I have a Mach 2 GT (r507) with 2 7800GTX in SLi , DFI NF4 DR mobo, Koolance Exos 2 (still not hooked up to the graphic cards yet), AMD Athlon 64 4800+, 5 hard-drives and 3 optical drives and a couple of CC lights. I intend to overclock the hell out of my graphic cards (currently running BFG OC at 490 core and 1315 memory on standard heatsink and fan) and from reading through the web these babies drains about 275 watts of power per card when overclocked. My current PSU is the Enermax 600watts which powers the whole thing at present. That is roughly a total of 550 watts for just the graphic cards!! and i still have a whole bunch of other components that are draining power. I also have another Enermax 480 watts PSU just lying around and i am thinking of TEC cooling the graphic cards alone with the Koolance Exos.
HERE IS MY QUESTION...HOW DO I RIG THE SYSTEM UP SO THAT I CAN RUN 2 PSU AT THE SAME TIME. SUCH THAT THEY BOTH START UP AND SHUT DOWN AT THE SAME TIME. It can be done right now just by shorting pin 2 and 4 or something like that in the ATX connector of the 2nd PSU and turning on the power supply to this unit.....BUT this is troublesome as i have turn turn on my main unit and the second PSU everytime i turn on the PC. I intend to use the 2nd PSU to power the TEC units of 80 watts each ...so total of 160 watts and the other remaining components like optical drives, hard discs, lights and fans and such.
I have read that there are ATX splitters that will do this job BUT i can't find them...anyone have any ideas or where to get these cable?
This must be the longest post ever in this forum!!
Thanks in advance.
Sash
Thanks in advance.
Sash
