How to install non-OS files to a sepearate non-BOOT drive
dugdiamond
!!!USE WITH CAUTION!!!
I made a decision to load just Win 7 to the SSD C: drive, and all other program files and data to the G: drive.
The only obstacle was when loading some programs - they want to automatically install to the C: drive. The solution involved making a registry edit, so that the G: drive is now the default.
It works like a treat.
Instructions are:
  1. Open the Registry Editor by selecting Start > Run > Regedit.
  2. Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion.
  3. In the right pane, double-click ProgramFilesDir and change the path in the String Editor to the drive and folder you want (i.e. H:\Program Files). You must also modify the entry for ProgramFilesPath. If your path is H:\ like mine is, the path would be H:\Program Files
  4. Exit the Registry Editor and restart your computer. My understanding is that some programs still require installation in the C:\Program Files folder, but I haven't found any yet.
NOTE:
It is best does do this directly after a fresh Win7 install.
Once done, all program files(x86) and program files folders MUST be copied to the new drive.
then reboot BEFORE delete the existing ones.
[DO NOT CUTnPASTE]
This is a great tutorial. Thank you very much for this Dug!
why not just use the custom install feature that is available with most proggies and change drive path to another drive???? This is what I do and it works well for me. This way I can easily manage what goes where.
not all installers have a customise option
