How to format NTFS in DOS??
maverik-sg1
Title says it all guys.
I would like to format my drive to NTFS format using DOS or other non-windows software.
Can someone tell me how?
Cheers
Mav
I dont think you can format your drive to NTFS via DOS they are totally separate formats. You can use FDISK to obliterate the drive and then repartition from there but that wont help with Linux or anything.. You should be able to get a floppy disk with the relevant software on it.
