Do you want to view your Blu-ray movie collection on your iPod? What if enjoy wonderful Blu-ray videos on your iPod on the way to work? The effective way to settle these problem is to apply Blu-ray to iPod converter. But what kind of software can convert Blu-ray to iPod with highest quality and easiest steps? Luckily, you are in the right place. Here we mainly introduce the most trustworthy and easy-to-use Blu-ray to iPod convert - AVCWareBlu Ray DVD Ripper.
Also you can find moer information from the following site:
http://www.rip-blu-ray-copy.com/blu-ray-dvd-copy.html
AVCWare recently released a wonderful Blu-ray to iPod convert - AVCWare Blu Ray DVD Ripper which brings you much convenience to convert Blu-ray movie to iPod. With it, you are enable to convert Blu-ray videos to iPod H.264 video, iPod MPEG4 video, and iPod family e.g. iPod nano, iPod classic, iPod shuffle, iPod touch without any loss of visual and sound quality. No matter you are greenhand or professional, this Blu-ray to iPod convert let you enjoy Blu-ray movies on your iPod at any time and anywhere you like. Sounds great? Why not try it now?
Guide: How to convert Blu-ray video to iPod
Step 1: Initialize the program and add Blu-ray file
After running this Blu-ray to iPod converter, click Add folder button, select a Blu-ray files in the dialog box that opens, and load it. The Loaded Blu-ray video information will be showed in the file list, such as Name and Status etc will be showed in the file list.
Step 2: Select and customize the output format
Click "Profile" drop-down button, then a new Window props up as below. You select the formats you need. For we need convert Blu-ray to iPod, we select the iPod video format as the output format. Then click "Browse" button to select a destination folder in the window that opens, click OK.
Step 3: Start to convert Blu-ray to iPod
Aafter finishing the above settings, check the needed file to convert in the file list, click Convert Checked Item(s) button on the main interface, to start converting Blu-ray to iPod. You can view the progress of converting Blu-ray to iPod from the progress bar at the bottom of the window.
After following the above basic operation and optional steps, you can easily convert Blu-ray to iPod to any kind of format and enjoy anytime you like. So fast speed, so easy to use steps, so clear interface, all the features give you a good impression, now get the full version to enjoy it!
Also,if you want to know more detailed information ,you can check here to find the answers: http://www.rip-blu-ray-copy.com/
