How to control a fan from my GPU's temperature?
saitrix
Hi,
Is there any software out there that can read my GPU's temp but it also has the ability to change the fan speed of a fan I have connected to the motherboard? I have been searching and haven't been able to find anything!
Do you have to manually set it up as speedfan is not detecting my HD4850's gpu temp at all. This is what I am currently using to control my cpu fan you see.
