I know it will. But see; my issue is, despite having a Huge case, Cooler Master Storm trooper, and a XL-ATX motherboard, in their infinite wisdom, Asrock decided to put the two PCIE 2.0 x 16 slots next to each other. Now I have custom coolers on each that reduce temps quite abit.Hell, my GTX670, with only one card in the case, is @ 1300MHZ, 7200MHZ memory or so...and scoring in lines with a heavily OC'ed 680 according to benchmarks. It is 99% in Uniengine and hitting 40c Load. Yeah. That's 99%, for 5 minutes, not 41c even once. That's damn sexy.
However; my second GPU...blocks the fans of my first...not entirely, about an inch breathing room. Still...not alot. As evidenced is, for the last few months I ran my second GTX670 next to it. Both would hit around 65-69c load...and this is during a cool winter, with a room with good air flow. Now, those are below the throttle point, yes, but not during summer...and they'd crash for me @ 71c, but I think that was because I checked and the Heatsinks had fallen off. So...my first GPU, right now, by itself, hits 40c @ full load, compared to 71c...that's a 21c difference, the lack of air flow makes that big of a change. Wow.
Now, I have two options that are viable. Sort of. I can put my second GTX670 in my third PCI-E 2.0 x16 slot...but for some reason, it only runs @ 4x...when I looked this up...it was because it will run @ 8x, only when in Tri-SLI
So it's 16 x 16 x 8...but if I only run the first PCI-E 2.0 x16 slot, for some reason, my third one is reduced to x4. It runs in this slot, I checked, I lost about 200 ~ or so points in my Uniengine Benchmark test.
I wanna see if there are any other benchmarks that has done this testing. I know I'll lose some, but ugh, poor motherboard design.
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157240
Don't laugh. I DID NOT get it because of the Fatality brandmark. I got it because it was on sale, for about 70$ off, and for that price, when I bought it, it was an insane deal. I get alot of people giving me shit about that.
My second option and one that seems simple, but comes with problems of it's own is: A PCI-E 2.0 x16 Riser card. I used one of my sound card abit back and found out about them.
This would give me ample space and air flow for my first card. HOWEVER...then the issue becomes...where do I put my second GPU? I can't just lay it over the PSU...it's own airflow would be blocked...and putting it on the floor would be...sloppy and I might step on it by accident sometime.
http://www.amazon.com/HOTER-PCI-E-Express-Riser-Flexible/dp/B0057M16Q8/ref=pd_cp_pc_0
SOmething like that. I used one for my sound card and it was ok.
Where I could put it, I do not know. I'm left in somewhat of a bind.
The x4 slot I could do right away. However, I'd rather see charts about it first and see how much I am really losing overall.
Thank you.
So my last PCI-E 2.0 runs @ x4, it says. However, I have two PCI slots as well, can tell by the markings what they are. Sadly, one of my PCI-E 2.0 x 16 slots is blocked off by the cooler on my GPU's. I have the Artic Cooler Twin Turbo II. As you can see, they work wonderful, but have left me wanting in this case.PCI Express 2.0 x163 (PCIE2/PCIE4: Single at x16 (PCIE2) / x8 (PCIE4), or dual at x8 (PCIE2) / x8 (PCIE4); PCIE5: x4 mode)
Thank you.
