As above, I am trying for over 400fsb but having some troubles, my RAM Runs at 799mhz if I run my CPU at 399fsb and my PCI-e at 100Mhz but if i go to 400fsb then my pci will go to 103mhz and subsequently my rig has lots of trouble/bsod's alot!
If I go to say 425fsb my RAM states that it is running, 849MHz? If i change the ratio it will only go higher say to 1049Mhz...
Can it run that high? How far can I push it? Its corsair XMS2 2x2GB CL5 (5-5-5-15) Should I get RAM that is capable of 1000MHz? Or is that not compatible with my MoBo (Asus P5Q-VM)
Any help is muchly appreciated!
Thanks
Joe
Thanks
Joe
