hey Welcome to the forums, I see you got dremel skills, I'm looking to start getting into Modding any advice on a good dremel to buy i've heard it's best to get a corded one as they obviously don't run out of power is there any particular model thats best? Any help is appreciated
Honestly Not sure i bought the 4000 model because it came with quite afew of the fittings for modding, Like the Circle cutting jig, Which i didn't use because you can't really use it on grills but yeah, I guess any of them will do, I was told the cordless ones are bad though you should avoid those, They lack the power needed for the mental cutting, 30k rmp really cuts through the metal easy, I'm not very strong at all and i did ok, Also the flexi extension is nice to have because you can cut circles way easier, Only downside is that model is around £115 from Big N Queer, I mean BnQ LOL.
I'm deffo no expert you should just ask in store, I see people doing the same thing as i did with the 300 model without issues.
