Hey peeps
I highly reccommend 'thenewboston.org' purely for learning gaming,udk its like a digital uni of great lessons and well structured which helps.
Friend me from facebook and go to the albums section where it says my photos and you should see some savvy results.
Heya DESTRO521
have I told you about/or have you heard of thenewboston.org? no kidding it's like a digital library of youtube video's, you mentioned UDK for one, they have 65 video's on the program and 2 advanced which must focus on KISMET (there programming language like Maya has MEL).
Go on facebook send a friend request and i'll accept but you can see in the photos/albums section the images and 'work-in-progress screenshots i've taken.
different socket, quad channel memory support.
i was just confused because i dont know of any SB CPU that is stock clocked at 3.2 GHz.
Ah I see, Well it's overclockers.co.uk that i cross-referenced that from and seemed good, hope I can get a stable overclock with it, might need the forums help on that, but i'm also thinking of having my COSMOS 2 door cut with the Hitman symbol and the latin words 'Merces Letifer' engraved on it :)
it will overclock just fine. seems like you are new to overclocking, so don't set your expectations too high, but the guys on this forum will definitely be able to answer all of your questions about it ;)
Well eitherway its good and i'll most likely be popping into the I.T. store to see the case as that is the part that initially holds the most wires.
2 Questions
A. Is it worth paying money to laser cut a window as COSMOS 2 hasn't got one yet or is it best to wait until they're available?
B. The power supply I picked was an Aerocool Strike-X 1100Watt '80Plus Gold'... This good enough for overclocking?
NOT everyday 3D work, but of hours stabilty in power?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-035-AE&groupid=701&catid=123&subcat=
