Help!
dalewakelin
Hello, i need help as i have just built a system using this board: Asrock 939n68pv-glan and when it starts up it has a post screen but there is no way to get off of it, you are just stuck with a post screen. I cant enter the bios, i cant start windows etc so what do i do to fix this? None of the onboard ports seem to be working either.
Cleared cmos but the same thing is happening, i found out i have the error 6B38. I dont know what it is yet but ill research it.
It turns out its a usb controller problem and there is no way to fix it. Great. R.I.P Asrock 939n68pv-glan. Thanks anyway. :p
