As the title says.
I am building a new PC over the next month, few goodies on the market that I'd like
and in the month following this I will be looking at water cooling
The build basics
Case: Cosmos s2
Motherboard: Rampage 4
CPU: Intel 3930
HDD: 240gb ssd + 2tb 3.5"
Optical: blu-ray rw
PSU: AX-1200
Video: GTX460 in SLI (upgrading to dual 680's WC)
Ok so my idea is to water cool the motherboard, CPU and video cards focusing mostly on the video cards as I don't see any big gain by going crazy on the CPU cooling.
Computer usage: Video converting 10%, Internet 20%, web design 10%, Games 50% and 10% for other stuff.
So with the video cards my main goal I was looking at running a 360 RAD (unsure thickness yet) in the roof for the CPU and dual 240x60mm in the bottom of the case from looking around XSPC seems to be the RAD's people get and seem happy with them. For a res I was looking at this dual 5.25" dual loop res that EK have with a basic acrylic front and flow indicators seems it would be good.
Ok this is where I become unsure on Pumps, blocks and barbs.
Mb Block: The only one I can seem to find in AU is the koolance one for the rampage 4 so I guess that is what I will be getting.
CPU Block: at the moment I have in mind a EK block but I have seen the XSPC blocks with lighting and they would look cool with he LED's being swapped for red, I will go performance over looks but if I can get looks and performance in one It would be good.
Pumps: At the moment I am looking at 2x EK-DCP 4.0 pumps. But this is a area I haven't payed much attention to in others builds so I do not really know much about the pumps, I wasn't going to get such a big pump for the CPU but the look of a small and a big pump next to each other would look a bit funny and it isn't much more for the bigger ones.
Barbs: These should be fairly easy but still that's how I may be wrong in thinking that lol, I would like compression fittings for a cleaner look but they are a fair amount more in cost so i may for with 1/2" and 7/16" tubing. I have seen in other builds people use SLI fitting and angle barbs to join the CPU and motherboard cooling together instead of using tubing for a cleaner look around the mobo. Is this a good idea to attempt or not?
Also do right angle barbs slow the water flow down much as compared to just having sweeping bends in your tubing or using 45 deg fittings?
Video card blocks: As I do not have the cards I will be water cooling yet this still has a few options. Should I get an aftermarket cooler for the cards or should I look at getting EVGA's ready to go WC 680 cards, But I would wait for the super clock edition to come out?
Notes: I am currently looking at buying my parts from [url]http://www.pccasegear.com[/url]
The build basics
Case: Cosmos s2
CPU: Intel 3930
Optical: blu-ray rw
PSU: AX-1200
