Help with new project
revox
My pc is dying and had it for years, my friend just got some great new parts for his pc and has some spare he is sending me. I don't have much money, and when i mean not much... i mean not much
So my old rig:
Acer T180
CPU: Amd Athlon 64x2 3800+ 2.00ghz
PSU: 350watt crap
RAM: 2GB crap
GPU: 9600gt SLi x2 Overclock
HD: 2x 1tb WD caviar black
Optical: Bluray Player samsung
Case: Acer crap
as you can see badly needs updating
My plan:
Case: NZXT Phantom
CPU: Q6600 (from my mate with mobo and ram)
RAM: 4gb DDR2
PSU: 750watt (good for upgrades when i have money)
GPU: 9600gt SLi x2 OC (will update to gtx 560ti SOC)
Optical: Bluray player samsung
Is this good? I will be buying case, psu and windows 7 just over £200
what psu are u gettin mate? cause if its a cheap 800w priced the same as a 650w dont count on it being able to handle 800w of gear mate
Always get a high quality PSU or you may see you investment get welded to the PSU cables when it goes bang.
Ye, i saw your video mentioning that when you built that budget PC, Coolmaster is a decent brand i'm sure they will be fine?
It will be a decent setup. I got almost the same
Cheers, will be miles better then what i got now.
Already have the case and PSU just waiting for the rest
will take some pics when built.
