Help with fans
Jacob.xray
Im looking for a set of fans that are available in both 140 and 120 size, have red blades (or red and black something along them lines) and have high static pressure Static Pressure (mm-H2O) about 1.7+
thanks to anyone who can find some just cant find any
Only ones I can think of are the Pobya Nano G's and the Xigmatek XLF, not sure on the static pressure though.
Your best bet is probably the Phobya Nano G or 2G fans. The Akasa Apache's also meet all of your requirements but they're just black not red and black. The Xilence Red Wings are red and black but i have no idea what the static pressure is on them. Xigmatek XLF's can be found in black and orange, they're a good choice too
yea the Akasa Apache look good but if i get a 4 pin (PWM) to 3 pin converter so i can use it with a fan controller will i loose any performance
I have a fan controller that does not accept pwm connections so I had to go from pwm to 3 pin which is no big deal and you will not loose anything. Just make sure that whatever you are hooking it up to it will accept the pwm interface.
