Anonfriend
Hi all,
I am new to the overclocking forum, joined last week when i bought parts to try my first ever overclock. I have now just built a brand new pc from the parts listed below.
I am trying to install windows xp (original cd with no service packs).
Everything seems to work fine until I get to the format NTFS request, when the 80GB disk formats to 100% and then a message comes up....
"Set up was unable to format the partition. The disk may be damaged.
Make sure the drive is switched on and properly connected to your computer. If the disk is a SCSI disk, make sure your SCSI devices are properly terminated. Consult your computer manual or SCSI adapter documentation for more information.
You must select a different partition for Windows XP.
To continue, press ENTER."
I have run my hard disk diagnostic tools and they tell me the SATAII disk is running perfectly.
I am at a total loss, having spent 15 hours trying to sort it out....please help.
Thanks,
Matthew
Thanks,
Matthew
