Grizzly
If you don't mind non LED fans Specialtech have a sale on and they have the Scythe GTs 1850rpm for £12.99 with 25% off. The GTs are some of the best fans there is for rads, high static pressure, CFM and noise to performance ratio.
http://www.specialte...-pid-10974.html
Type MADNESS into the coupon code box in your basket to get 25% off.
That is perfect! But my parents are away for the week and I don't have enough money to buy even one right now.
But even with 25% off they would cost almost twice as much as the SickleFlows and, on paper at least, are worse in almost every way.
I know they're supposed to be good, I've heard them mentioned before, but at that price what is it that makes them better than the SickleFlows?
EDIT: Have read what reviews I could find on the 2 fans, both from x-bit labs, suggests what is written on the spec sheet for the sickleflows is far from truth, they are a good 5-6dBA louder than the gentle typhoons when running at same speeds and performs worse. When the sickleflow runs at 1910 performance is similar but sickleflow is 7dBA louder
