grandpatzer
This is what I have achieved so far:
my Mobo has LLC: Disabled, 25%, 50%, 75%, Enabled.
I'm assuming Enabled is 100%(?)
there is vcore in HWINFO and it's simply called Vcore, however this motherboard and 2500k that I today installed seems to always have too low readings
When putting Vcore to AUTO it reads MIN 0.600v, MAX 0.848v and now in IDLE Current: 0.632v
So far I have had BIOS DEFAULT and just increasing multiplier to 42x and IBT (Intel Burn Test) crashes after just 2 runs.
41x is 100% stable at this stressing: 2hour small FFT Prime95 + 20runs IBT 2048mb (High) stable with in BIOS everything at DEFAULT besides the multiplier.
I did try following: LLC:75%, Vcore 1.45v, 44x, Interna PLL overvoltage enabled. Everything else is DEFAULT I think the default PLL is 1.80v.
First time running IBT it passes, 2nd time I try IBT 2048MB it crashes after just 2 runs, warning me that PC not stable.
