help me choose
kingnova
Hi peeps I need help i cant choose between the Cooler master Storm Scout and the Lancool Dragon-Lord PC-K58. I'm leaning towards the Lancool because it has better cable management just means I'll have to attack the inside with spray. What do you guys think?
Is it the K-58W? Cause if not I would go with the CM Storm Scout because the scout has a window...
If you can.. go with the lancool dragonlord k-62. Its black on the inside already and has a bit more features than the K-58W
+1 on the scout storm here i have one myself and its an excellent case and the cable management isnt too bad! only thing ive noticed that it lacks is a hole for the 4/8 pin cpu at the top of the m/b tray other than that i managed to do all the cable management i needed
The only problem with the lancool dragonlord k-62 is it has that stupid big window so you see the PSU and the drive bays. I don't like that, when i put a window in I do it so you only see the motherboard and GPU's. Just a personal thing i spose.
On the CM Storm Scout can you get the 24pin ATX power cable behind the motherboard tray and close the door?
Because I saw a review somewhere and they said it couldn't be done.
You're definitely right about that. :D
Thing is though.. I dont know when you will be able to buy it and how much it will cost you when you do...
Yea that's the problem need a case as soon as, coz i got my system setup on the desk at the moment just waiting for someone to spill coffee on it LOL
When you're done building your system, could you post your rig on the forums?
Would love to see what the final product looks like :D
