Help In Select Dd2 Memory...
pabloxs
Which is the best ddr2 memory for overclocking?
Ive just bought a 2x2GB. PatriotViper8500 and I cant get to overclock it beyond the specified (1066)
:worship:
THANKS A LOT
Saludos desde México!!!
MB. XFX nForce780i
IntelCore2Duo E8400 @3.7GHZ
2x2GB PatriotViper 8500 @1066
2x250GB WD HD @7200-16MB
2xXfx9800GTX 512MB
CM CosmosS1000
Its not the memory, its the amount of it that you have, the motherboard probably killing itself trying to command all that memory.
