i am about to do my first water cooled system and id like to know ive got the right parts before i start
I currently have:
Cooler Master Cosmos II
Windows 8.1
Corsair Axi 1200W Fully Modular 80+ Platinum Power Supply
LG BH16NS40 16x Internal Blu Ray Write with SATA
MSI R9 270 GAMING 2GB GDDR5 Dual DVI HDMI DisplayPort PCI-E Graphics Card (X2)
Crucial MX100 256GB SATA 6Gbps 2.5inch 7mm with 9.5mm adapter SSD
Seagate 3TB Barracuda Hard Drive - 3.5" SATA-III - 7200RPM 64MB Cache
Intel Core i7-5930K 3.50GHz Socket 2011-V3 15MB Cache
Asus RAMPAGE V EXTREME X99 Socket 2011-v3 8 Channel Audio eATX Motherboard
G Skill Ripjaws 4 F4-2666C15Q-16GRR 16GB Memory Module Kit with Heatspreader - Red(X2)
I am looking at buying:
Alphacool NexXxoS ST30 Full Copper 240mm Radiator
Alphacool NexXxoS ST30 Full Copper 360mm Radiator
Alphacool Repack - Dual Laing D5 - Dual 5.25 Bay Station
Alphacool VPP655 (X2)
EK-Supremacy EVO - Nickel
EK-FB KIT ASUS R5E - Nickel
EK-RAM Monarch X4 Clean CSQ - Nickel (X2)
Mayhems Premix Fluid for Water Cooling 1 Litre : BLOOD Red
Mayhems Ultra Pure H20 Water : 1 Litre
Arctic Cooling MX-4 Thermal Compound
Streacom Thermal Grease Remover
i am unsure on what fittings/ tubing to get
i plan to run the loop to a triple radiator in the top and then through the blocks to the radiator at the bottom then back to the pump/radiator. i would also like to put in some kind of drainage system so i can perform maintenance when needed are there any other parts i need to complete my build?
I currently have:
Windows 8.1
