hello am newww
CPU - Intel Core 2 Quad Pro Q6600 - £149.49
CPU Cooler - Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775 - £16.42
GPU - Asus HD 4870 1GB - £166.74
RAM - not sure?
HDD - Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII *32MB Cache* - £78.18
DVD - Pioneer DVR-216DBK 20x DVD±RW Dual Layer Internal SATA - £17.76
PSU/Case - Coolermaster Elite 330 Black Case With CM eXtreme Power 650W PSU - £68.50
Motherboard - Asus P5Q-E P45 Socket 775 8 channel audio ATX Motherboard ? - £113.85
Monitor - Samsung SM2433BW 24" TFT Monitor 1920x1200 20000:1 300cd/m2 5ms VGA/DVI - £209.99
So...how is it looking? will this all integrate together nicely?
what ram shall I go for? can't be OCZ as it may not work with asus motherboard...needs to be 4gb and around £50, cpu will be clocked to around 3.0ghz...any of these good?...
ebuyer.com/product/130429
ebuyer.com/product/140132
ebuyer.com/product/153130 (cant post links till i have 15 posts :D )
am itching to order...can't wait :D
thank you!!! i was looking for g.skill ram...saw loads of US sites, but none in the UK apart from one which was out of stock...
the G.Skill spec is the best value for money for spec for sure! but...how reliable is it?
think I got my answer...I'll post up the final final spec shortly though...in the correct section :)
G.Skill are extremely reliable mate, my brother has had the same sticks running fine for near 2 years. :)
the last concern i have is the psu...
are the Coolermaster PSUs good quality? Will it really put out 650W?
they are dude, there's alot of other brands pretty good aswell, i would go with corsair HX series and ocz mod Xstream pro aswell, both are modular and work pretty good (also cheap)
where's a good place for cases? if i buy the PSU separate, I don't want to spend too much on a case...not really seen anything I like on ebuyer
£20-£30...if it's something SUPER sexy i'll pay £40 :D
all cases come with a rear fan right? is it worth having a front/top fan too?
hey dude, have any particular choice? like mid tower / full tower / a brand you like? if not i will search for some cheap cases (but good ones)
look at this site they have cases and other gear for you if you need another one i give ya more.
looking for an ATX tower...I guess that's a mid tower? I'll check out that site right now...I'm after something simple and black to match my samsung tft which is piano black
that is nice! but twice what i want to pay :(
...i'm thinking i might just put it under the table...carpet dust won't be an issue as the floors are wood...so maybe a cheapo £20 black case would do it...
i really like that lian-li small box aswell, shame that its mini
hmm thats bad then :(, the 690 is one of the best budget cases from cm, i will take a look at other stores on other brands aswell :)
small update
with some help from charlie (i remembered his post) this case could work
i looks pretty good.
also get the link for charlie rig
