Dawelio
Active member
Hey guys,
So my old trustworthy Logitech G35's are slowly breaking down on the earpads, which unfortunately is fake leather/plastic and not memory foam.
I have gone through 3 of these already and the G35's are well fit for me, but once I tried the new Sennheiser GSP 300's and their memory foam ear pads... Man, I was so sold.
And I have tried searching around on the web to see if it anything comes across, but nothing major so far... So now I'm asking if you guys may know any similar type headsets out there, with over the ear, memory foam?.
What I'm after is this: closed, the earcups should not just be able to tilt up and down, but also some to the sides, somewhat deap earcups (so that my ears doesn't touch the inside of the earcups, ie the Sennheiser Game Zero's are too short in distance for this, as an example).
And that's about it, and I don't have an dedicated soundcard. Either onboard audio or USB connection.
Also I do like the black and blue on the GSP 300's, since my setup is the same. But all black is fine as well.
Any advice is welcome
Thanks,
Chrazey
Thanks,
Chrazey
