Lynx
I was only saying. If your on such a power saving drive then surely thats a better idea?
I see what you mean but the reason that I prioritize power savings is BECAUSE I have it on 24/7
pretty much what i would sayIt's very simple - not possible. Gaming on this resultion is not possible with a 200 pound cars.
I'd say you'd get pretty close to gaming on a single card at that res.
My single 670 works absolutely fine with triple screens at 5760x1080 without an overclock.
Maybe not max settings on everything - but he could still get comfortable frame rates I think.
As for the AMD vs nvidia for multiple screens....
I personally have found nvidia far easier to work with. AMD still requires an active display port adapter on their cards which costs an additional 70/80 quid. Nvidia on the other hand just allows screens to be plugged in straight to the card without any additional adapters, so going nvidia saves a fair bit of money there.
It depends on the user though...
I'm personally absolutely fine with dropping settings down to medium or high if I have to. I can't even tell the difference in all honesty. I don't let my framerates drop below 45ish anyway and pretty much every game I can max out settings and play fine. AC3 for example - highest settings all round across triple screens and there's no lag whatsoever.
I say get a single card, as good as you can afford and see how it goes. If you think it's a problem then you can always drop the settings temporarily until you can afford a better card, or a second card for SLI.
Don't listen to people who haven't tried running triple screens on a single card because they can only speculate, and it's incredibly rare you'll find anyone else out there trying to run your specific resolution with your specific card.
Just get a 660/660ti if you can afford it and see how it goes.
But a 670 is about > 300 bucks and the difference to a 660 is huge![]()
I'm running 3x 1080p screens, he's running at quite a lower res. That may make up for the difference in GPU power - but again, nobody can tell unless they've actually tried with his specific config.
My point still stands however - if he bought a single 660, he can still try it out. The screens are gunna run fine in windows, so he can use 3 still, and if he does need to, he can always turn down the settings in games, or even switch to 1 screen if need be until he can afford something more powerful, or SLI.
I feel too many people rely on benchmarks these days, and forget that turning settings down actually makes a big difference.
I'm using a highend overclocked 670 and play on 1920 x 1080 with around ~70 FPS BF3 on max settings, so don't tell me can play with a much worse card on a much higher resulution and still keep the fps up.![]()
Dirt3 - no you won't drop below 30FPS.
GTA IV - doubt it...
Black Ops you can't even play triple screen properly without mods.
CoD games aren't coded for it, so in setting it at that resolution it just stretches a single screen across 3 and this happens:
It doesn't look as bad like that, but it's really difficult to play properly like that, and is pretty disorientating too.
You can get mods for it - but they will get you VAC banned if you use them online, so you can only play single player like that.
